I have created a new project and one of the sources needs access to multiple include
directories. I have edited the new make file as follows:
NAME := testPlatform
$(NAME)_SOURCES | := testPlatform.c |
$(NAME)_INCLUDES +: -I./WICED/RTOS/FreeRTOS/ver7.5.2/Source/include
After clean and build, I get a strange string in the config.mk file (in the build dir tree)
that looks something like
testPlatform_INCLUDES := -I./app/testProgram/testPlatform-I./WICED/RTOS/FREERTOS/ver7.5/2/Source/incude
no space between the include specs and the compile fails. Have replaced +: with other syntax choices but
same result. If I edit config.mk and add a space, include files are found correctly. But, if I ever do a clean,
I loose that info from the config.mk file.
Also is there a list of significant make variable names that mean something in project make files? It took a while to find the
xxx_INCLUDES name in an example and also the $(NAME)_PREBUILT_LIBRARY := xxx.a for use in creating project-wide
libraries. Even if its just a list significant names, that would be a help..
SDK 3.x
- sdk 2.4.1
Don't add -I in $(NAME)_INCLUDES and the include path should be relative to component directory!
Try +=
Thanks for the reply. But, it does not work in my build environment.
I have a project in the apps directory:
apps/testSystem/testPlatform
in testPlatform.mk, I have the line
$(NAME)_INCLUDES += -I./WICED/RTOS/FreeRTOS/ver7.5.2/Source/include
I do a clean followed by a make testPlatform-myPlatform and see
the following in the build/testPlatform/config.mk
testPlatform_INCLUDES | := -I./apps/sensorPlatform/testPlatform/-I./WICED/RTOS/FreeRTOS/ver7.5.2/Source/include |
The field will not resolve into an acceptable include directory due to the missing " ".
If I edit the config.mk and "don't" do any further cleans, it works. But, I admit this a clumsy work around.
THanks,
Chuck
Thanks, finally had time to try it. I already had relative paths in place, but
had not tried leaving out the "-I".
rtis
