EyLa_3227556
10 replies posted 5 replies posted 10 questions asked
What  is the correct way to architect dual connectivity scenario (BLE & WiFi) ?
I'm using ST32F412+CY4343 combo module and SDK 6.4
Can you specifically refer to the following use cases:
- BLE advertising in parallel to WiFi connection
- BLE connection in parallel to WiFi scanning
If the 2 protocol can not operate concurrently - is it the app's responsibility to manage the sequence or is it done by the SDK?
e.g. WiFi api call discards/stops/closes any BLE activity and vice versa - BLE api call disconnects/closes any WiFI activity?
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hi EyLa_3227556​,
Could you please refer ble_wifi_introducer example in WICED SDK? It demonstrates simultaneous BLE+WiFi operation.
FYR: /43xxx_Wi-Fi/doc/WICED-BLE-WiFi-Introducer.pdf
SheetalJ
Hi EyLa_3227556​,
