We have encountered some problems and hope you help
we can compile successfully with the CYW943907WAE4 platform, but can not succeed on the CYW943012EVB_02 platform. The version we use is WICED-Studio-6.2.0.72
What does the following error mean, how can I successfully compile?
WICED/RTOS/ThreadX/ThreadX.mk:84: *** No ThreadX port for architecture.  Stop.
make: *** No rule to make target 'build/test.bt_mfg_test-CYW943012EVB*/config.mk', needed by 'main_app'.  Stop.
WinstonF_61
100 likes received 100 sign-ins 50 solutions authored
This device is not supported in the broad market. I suggest you get in touch with the Cypress Sales team to link you to the right team to help you.
Winston
WinstonF_61
Winston
