I'd like to use Color LCD controlled by WICED.
Is there any module available?
I'd also like to have sample code for the LCD.
* STM32F429 seems to support LCD.
HuFi_1747246
First like received
The FTDI FT800 can be useful here to drive a good-sized screen using few resources on the MCU; the FT800 has video buffer, TFT drive, and a graphics accelerator on a single chip. It also provides a resistive touchscreen interface. Connects via SPI to your MCU.
Here are a couple of github repos with example code for the electric imp wifi+cpu module:
reference/hardware/FT800_EVE at master · electricimp/reference · GitHub
asm/imp_ft800 · GitHub
you may try SPI controlled TFT.
HuFi_1747246
First like received
Thanks Hugo.
Note that you just earned the Coach badge noted here for sharing code: Participate in the Community Forums and Earn a $50 Amazon Gift Certificate!
Appreciate the help.
Thank you for your information. I'll check them.
