Changing WWD Thread priority
prpuc_2175051
First like received
We are working on BCM4343W based WiFi Murata module with ARM Cortex M4 based platform (interfaced through SDIO) and uses ThreadX/NetX. The WICED SDK version we are using is 3.5.2
wwd thread priority is set to highest which is 0 (in case of ThreadX). When we change this priority i.e. set to lower priority e.g 5 then driver is failing.
Is it expected to work with other thread priorities?
On Similar base, we also have BCM43362 (Murata SN8000ufl) module with ARM Cortex M4 based platform (interfaced through SPI) and uses ThreadX/NetX
When we change wwd thread priority for BCM43362 (i.e. ThreadX priority 0, 5, 20), it works fine.
So we expect it should also work for BCM4343W.
Please suggest why it is failing for BCM4343W.
Thanks & Regards,
Pratik.
