Wi-Fi Combo Forum Discussions
LiGa_2316726
10 sign-ins 5 sign-ins First reply posted
I would like to change the spi clock of the flash interface .
Can it be done via the Wiced or the OpenOCD?
This is not a straightforward and simple process. But, you can try changing the parameter NORMAL_READ_DIVIDER in platform_spi_flash.h file. Location:
43xxx_Wi-Fi\WICED\platform\MCU\BCM4390x\peripherals\platform_spi_flash.h
Aditi
DheerajPK_41
May I know which chip/product are you using?
-Dheeraj
SheetalJ
Hi @LiGa_2316726 ,
Changing the frequency of sflash for CYW2070x devices needs to be done at firmware level. There is no way to change it in application.
LiGa_2316726
I am using the CYW43907.
Aditi
