I'm having trouble loading the WiFi firmware during wiced_init(). In WWD/internal/bus_protocols/wwd_bus_common.c,
result = host_platform_resource_size( resource, &size );
    if( result != WWD_SUCCESS )
        WPRINT_WWD_ERROR(("Fatal error: download_resource doesn't exist\n"));
        goto exit;
    if ( size <= 0 )
        WPRINT_WWD_ERROR(("Fatal error: download_resource cannot load with invalid size\n"));
        result = WWD_BADARG;
        goto exit;
size would come up to be 0 causing that "Fatal error: download_resource cannot load with invalid size\n".
Any idea why?
Problem solved: it was a hardware wiring problem (caused by an error in the datasheet). More info here:
http://cloudconnectkits.org/forum/topic/feedback-error-datasheet
Thanks for getting back to us wit the resolution josh.yu_1995211
