- Email to a Friend
HI all,
I 'm using BLE functon on WICED-SDK_3.3.1.I plan to add two uuid128bit services, it appeared a strange question. If I just add one,when connect it, I can see this service with iPhone, but if add two, when connect it, I can't see any services.The attachments are my gatt_db file.
I run example "ble_proximity_reporter", it has multiple uuid16_services, there is no this problem.
What causes this problem? Hope someone help me a look.
- Email to a Friend
Moved to Wi-Fi Forums from Smart, adding Wi-Fi Apps team.
Team - Note this is similar to the previous question posted by the user here: 128-bit UUID service x 2
- Email to a Friend
Hello Jixing,
We have found a fix for this issue where defining consecutive 128bit uuid services will result in an error. The solution will be included in our next release which is scheduled for the end of September. Thank you for your patience.
Jaeyoung
- Email to a Friend
jaeyoung wrote:
Hello Jixing,
I'm wondering if you mean SDK-3.7.0-3 or not...
I didn't find this issue mention in the release note...
- Email to a Friend
You may download the new SDK, WICED Studio 4.0, which includes this fix from the following link.
WICED Studio 4.0 has been released....
Jaeyoung
