Dec 15, 2020
09:53 PM
Dec 15, 2020
09:53 PM
I found that a new QDID had been registered on Bluetooth Sig.
QDID:160340 - Component (Tested)
CY-WICED 4.1 BLUETOOTH Host Stack, 4.1
We have BLE project with CYW4343W(1DX) and WICED(6.4.0).
Can I use this QDID for BT SIG certification ? Should we update WICED to 6.6.0 ?
Labels
WICED Studio
Wifi+Bluetooth
07:05 AM
Dec 18, 2020
07:05 AM
- QDID:160340 holds the notion for a new Bluetooth Host Stack of Cypress/Infineon, which is Bluetooth 5.2 core spec compliant, and the actual Software Version Number of it is BT-STACK-1.7.6173. However, CYW4343W is Bluetooth 5.1 compliant and there is no sign that CYW4343W is now using BT-STACK-1.7.6173.
See the link below for more information:
Launch Studio - Listing Details (bluetooth.com) - Updating to the newest IDE is always better in general. So you can update to WICED 6.6.0 if you have no reason not to.
07:05 AM
Dec 18, 2020
07:05 AM
04:54 PM
Dec 20, 2020
04:54 PM
Thanks!
OK, I will apply QDID:115853 by referring to the following.
<https://community.cypress.com/message/186649#186649>
By the way, how can I check which version number of BT-STACK is used in the combination of WICED and controller (4343W)?
B.R.
