Can WICED use new QDID ?
YoKu_3799151
5 replies posted First question asked First reply posted
I found that a new QDID had been registered on Bluetooth Sig.
QDID:160340 - Component (Tested)
        CY-WICED 4.1 BLUETOOTH Host Stack, 4.1
We have BLE project with CYW4343W(1DX) and WICED(6.4.0).
Can I use this QDID for BT SIG certification ? Should we update WICED to 6.6.0 ?
Charles_Lai
500 replies posted 250 solutions authored 250 sign-ins
  1. QDID:160340 holds the notion for a new Bluetooth Host Stack of Cypress/Infineon, which is Bluetooth 5.2 core spec compliant, and the actual Software Version Number of it is BT-STACK-1.7.6173. However, CYW4343W is Bluetooth 5.1 compliant and there is no sign that CYW4343W is now using BT-STACK-1.7.6173.
    See the link below for more information:
    Launch Studio - Listing Details (bluetooth.com)
  2. Updating to the newest IDE is always better in general. So you can update to WICED 6.6.0 if you have no reason not to.
Charles_Lai
Thanks!
OK, I will apply QDID:115853 by referring to the following.
<https://community.cypress.com/message/186649#186649>
By the way, how can I check which version number of BT-STACK is used in the combination of WICED and controller (4343W)?
B.R.
