Hello, I followed this link to debug with my CYW9443907AEVAL1F:
https://community.infineon.com/t5/Resource-Library/Downloading-through-Jlink-Segger-in-WICED-SDK-6-2...
And I followed all the instructions there in the word file to debug with GDB
It seems like it try but the log says that it cannot read the registers
I'm going to attach the complete log., Does anybody knows what its wrong?
Also I saw a comment in that post about doing a target with the debug option, I made this:
test.console-CYW943907AEVAL1F-debug JTAG=jlink-native JLINK_PATH="C:/Program\ Files\ \(x86\)/SEGGER/JLink_V720/" JLINK_EXE="JLink.exe" JLINK_DEVICE=CYW43907 JLINK_SPEED=auto JLINK_INTERFACE=JTAG JLINK_AUTO_CONNECT=1 download debug
But in this case I got an error like this
warning: File "C:\Documents\WICED-Studio-6.6\43xxx_Wi-Fi\.gdbinit" auto-loading has been declined by your `auto-load safe-path' set to "$debugdir:$datadir/auto-load".
To enable execution of this file add
add-auto-load-safe-path C:\Users\H448134\Documents\WICED-Studio-6.6\43xxx_Wi-Fi\.gdbinit
line to your configuration file "$HOME/.gdbinit".
To completely disable this security protection add
set auto-load safe-path /
For more information about this security protection see the
"Auto-loading safe path" section in the GDB manual. E.g., run from the shell:
info "(gdb)Auto-loading safe path"
.gdbinit_attach:1: Error in sourced command file:
localhost:3333: No connection could be made because the target machine actively refused it.
But when I set that instruction in gdbinit file, when I run again the target, WICED STUDIO will override it and delete that instruction, does anybody knows how add it?
Thanks and regards
Hi @vanessa_diaz ,
You can refer to our latest document attached and check the steps you followed.
you will be able to debug through jlink with the steps given in the document.
Rakesh B G
Hi @vanessa_diaz ,
Rakesh B G
Thank you very much, it was the solution 😁
