On the CYW943907AEVAL1F evaluation board, I want to use an external JTAG device plugged into the J3 connector. I have looked at the example given in "OpenOCD-WICED", but I still have a question about the hardware connection. Aren't you driving against the JTAG signals coming from the FTDI chip if you close the SW4 switches and plug in a JTAG device?
ispn:38946:1:0
l1:314:1:0
Your understanding is correct. The configuration is such that we dont expect to program the chip using FTDI and external JTAG at the same time. When the device is powered up using 5V supply through the power jack J8 instead of USB, the external JTAG is used.
In case the device is powered using USB, WICED is forced to use the JLINK executable to download using JTAG. A flag need to be mentioned in the build string to ensure that JTAG is used.
