Hello.
I want to send byte stream on SPI.
I have to use SPI in a way where LSB (less significan bit) is transmitted before MSB (most significant bit).
I set SPI_LSB_FIRST but no results ...
spi_config_fpga.port = WICED_SPI_2;
spi_config_fpga.chip_select = WICED_GPIO_NONE; /* CS gestiti via SW */
spi_config_fpga.speed = 1e6; /* Massimo 40MHz, 25ns Hold Time */
spi_config_fpga.mode = SPI_CLOCK_RISING_EDGE | SPI_CLOCK_IDLE_HIGH | SPI_NO_DMA | SPI_LSB_FIRST | SPI_CS_ACTIVE_LOW; /* see Document Number 002-14829 Rev. *K page 22 */
spi_config_fpga.bits = 8;
/* init 'spi_config_fpga' spi */
status = wiced_spi_init ( &spi_config_fpga );
WICED Studio Wi-Fi Combo
Can you share your complete application code with us? Is data transfer happening at all? Can you share the terminal logs that you get when the application runs? I am not sure what do you mean by this -- I set SPI_LSB_FIRST but no results ...., is data transfer not happening at all or LSB bit isn't getting transmitted first?
Aditi
Data is transferred but,
for example,
if I want to transfer byte 0xBA that is 10111010 in binary
I want that SPI put out bits in this way 01011101 ( = LSBit first) and not 10111010 (MSBit first)
