JuMo_1762556
I am using WICED-Studio-6.0 on CYW943907AEVAL1F platform.
I can't make both OTA and OTA2 work for CYW43907 now.
Please give your comments and advise to shoot this problems.
For OTA2, I tried the following procedures;
https://community.cypress.com/community/wiced-wifi/wiced-wifi-forums/blog/2016/08/23/sdk-370-ota2-up...
I can't succeed step 6. I couldn't make it
"After download, reboot the target by "update_reboot" to extract the new firmware.
After extract, reboot the target again to start new firmware running. "
For OTA, I tried the following procedures;
https://community.cypress.com/community/wiced-wifi/wiced-wifi-forums/blog/2015/05/22/wiced-ota-sdk-3...
When I tried "Perform factory reset on the WICED evaluation board" but I couldn't succeed.
Seems to me, software updated was done but can't make factory reset.
PriyaM_16
25 solutions authored 10 solutions authored 5 solutions authored
For ota_fr snip, Kindly include download_apps in your make target.
E.g. snip.ota_fr-CYW943907AEVAL1F download_apps download run
The console should show the FR_APP being downloaded in the device as below:
Downloading FR_APP build/snip.ota_fr-CYW943907AEVAL1F/binary/snip.ota_fr-CYW943907AEVAL1F.stripped.elf at sector 17  address 69632...
If the factort reset part doesn't work, make the following changes in your platform files:
In platforms/CYW943907AEVAL1F/platform.h ​
​Replace
#define PLATFORM_FACTORY_RESET_BUTTON_INDEX  ( PLATFORM_BUTTON_1 )
with
#define PLATFORM_FACTORY_RESET_BUTTON_INDEX  ( PLATFORM_BUTTON_2 )
In platforms/CYW943907AEVAL1F/platform_config.h
Add the following lines:
#ifndef OTA2_SUPPORT
#define PLATFORM_HAS_OTA
#endif
PriyaM_16
​Replace
with
#endif
Thank you for the answer.
  I confirmed this message on my console.
> Replace
> with
  I tried but it doesn't fix the problem.
> #endif
  This setting is already included.
I think I can write a new software by OTA but I can't change back to the original software
by factory reset. I don't see D1 LED flash.
May I ask one question just to clarify the procedure?
Hold the SW1(USER_1) button. While you are holding the button, press and release the RESET button momentarily. Keep the SW1/USER_1 button pressed for further 5 seconds.
Have you followed the same steps?
Also kindly try in the recent SDK 6.1
Yes, I followed the exact same procedure (steps).
I tried SDK 6.1. LED D1 flashes but software doesn't come back to the original one.
After momentarily pressing and releasing the reset button, Keep the SW1 pressed unless the LED stopes flashing.
A demo can be seen here: https://youtu.be/m-O9XoDqnwk
Thank for the video.
I confirmed that I am doing same procedure as you.
In you video, LED D1 and D2 start blinking but my result is only D1 blinking.
My board looks different from yours.
I am using CYW943907AEVAL1F board.
His board is CYW54907 based. This is essentially a CYW43907 with .ac added.
I succeeded to do Factory reset for OTA on SDK6.1.
The position of following code is wrong in platform_config.h;
#endif
If I put these lines in front of [#include "platform_config_bsp_default.h"] Factory reset worked.
(But still doesn't work on SDK6.0.)
Thank you for your support.
Yes. That would be the correct location to be able to reset the device.
