Wi-Fi Combo Forum Discussions
HIUR_3769846
First like given Welcome!
I checked the document and template for "Cypress Wi-Fi Regulatory Manual" show in below URL.
https://www.cypress.com/documentation/application-notes/an225347-cypress-wi-fi-clm-regulatory-manual
Reading document, I understand that if I would like to changed target powers ,Measure, support band(NS), I need to submit modified file based on template to cypress. Could you tell me how to submit our modified file?
My motivation is changed the target power and to set not support channel such as over ch100~.
PriyaM_16
25 solutions authored 10 solutions authored 5 solutions authored
Kindly create a case in Cypress Mycase system with the Inquiry type set to IOT:CLM. You can provide the template for the required countries/regions in the case. The power templates are provided in a zip file on the same URL.
PriyaM_16
Thank you for your quick reply.
I find and will send the message in New Technical Support MyCase.
