I am using CYW954907AEVAL1F development board. I was trying to enable Access Point in channel 34 with 40 MHz bandwidth. I am using WICED 6.4
The error i am getting is as below.
Set chanspec IOVAR failed result=2020
Error: wwd_wifi_start_ap failed
May i know what is the issue here? I also want to disable DFS for channel 52 @ 20 MHz bandwidth. We are doing a conducted test inside RF shield box. so, we are not interfering with other RF devices.
Can you provide us, information about above two queries?
Regards.
softAP
WICED Studio
Wireless MCU
I think CH 34 is in the description list, but it is disabled in our regulatory release , we do it according regulatory rules. for DFS setting, we have regulatory document released publicly .
https://www.cypress.com/documentation/application-notes/an225347-cypress-wi-fi-clm-regulatory-manual
you can have a reference .
hello:
which country code are you using now?
I used US as country code. I also checked with other a few country code. The result is same.
Did you have a try with our test demo?
The directory is : 43xxx_Wi-Fi\apps\test\mfg_test
so we can set different commands with UART interface on PC environment.
I added iPerf test program and added the command for AP.
or you can add the command call in this function:
static wwd_result_t internal_ap_init( wiced_ssid_t* ssid, wiced_security_t auth_type, const uint8_t* security_key, uint8_t key_length, uint8_t channel )
you can find a good position in this method , there have many defines before AP is created.
no matter which project we use, the scenario, i mentioned you is having same behavior.
can you please check in your side with WICED 6.4, for the channel and bandwidth i mentioned, country code set to US.
do you have any update on these issues?
regards
I have a look into the difference of channel setting and found the following difference
in WICED 6.4
if ( (result = wwd_wifi_set_chanspec( WWD_AP_INTERFACE, channel, &wwd_wifi_sleep_flag )) != WWD_SUCCESS )
WPRINT_APP_INFO (( " Set chanspec IOVAR failed result=%d\n", result ));
return result;
where in patch
data = (uint32_t*) wwd_sdpcm_get_ioctl_buffer( &buffer, (uint16_t) 4 );
CHECK_IOCTL_BUFFER_WITH_SEMAPHORE( data, &wwd_wifi_sleep_flag );
*data = channel;
CHECK_RETURN_WITH_SEMAPHORE( wwd_sdpcm_send_ioctl( SDPCM_SET, WLC_SET_CHANNEL, buffer, 0, WWD_AP_INTERFACE ), &wwd_wifi_sleep_flag );
So, may i know how shall i apply the patch? I just change the above portion of code and the behavior is still same.
Looking for your help on this.
Regards.
we should have more difference than you pointed out. I think the most important is here:
please apply the patch and record in detail.
bandwidth = wifi_utils_get_bandwidth();\ |
// you can set a accurate value like 40, 80 here to track if the band width is set rightly.
WPRINT_APP_INFO (( " Bandwidth : %d\n", bandwidth )); | |
if ( bandwidth == 40 ) | |
chanspec = (wl_chanspec_t) htod16((channel | WL_CHANSPEC_BW_40 | WL_CHANSPEC_CTL_SB_NONE)); | |
else if ( bandwidth == 80 ) | |
chanspec = (wl_chanspec_t) htod16((channel | WL_CHANSPEC_BW_80 | WL_CHANSPEC_CTL_SB_NONE)); | |
else | |
chanspec = (wl_chanspec_t) htod16((channel | WL_CHANSPEC_BW_20 | WL_CHANSPEC_CTL_SB_NONE)); | |
chanspec |= wwd_channel_to_wl_band( channel ); |
sorry, I made a mistake, the before folder should be after , the after should be before.
You can have a check also .
After integration, i did testing with 3 different AP settings as below. Here i start AP with SSID called tester with wpa2 and 1234abcd as passkey.
Test -1
start_ap "tester" wpa2 "1234abcd" 40 20 192.168.1.2 255.255.255.0
In this case channel i selected 40 with 20 MHz bandwidth
I can see RF output after i received the last response. no issue in this case. Below is the log info
Bandwidth : 20
calling chanspec IOVAR with chanspec=d028 channel=40
IPv4 network IP: 192.168.1.2
IPv6 network IP: FE80:0000:0000:0000:8C45:00FF:FED6:3B58
Test - 2
start_ap "tester" wpa2 "1234abcd" 34 40 192.168.1.2 255.255.255.0
In this case channel i selected 34 with 40 MHz bandwidth
I can't see RF output. got error. Below is the log info. I need to perform processor reset after i get the log below. as processor does not respond with serial command.
Bandwidth : 40
calling chanspec IOVAR with chanspec=d822 channel=34
=== EXCEPTION ===
Debug event (e.g. breakpoint)
DFSR : 0x00000000
DFAR : 0x00000000
IFSR : 0x00000002
IFAR : 0x004C8B7E
CPSR : 0x000001D7
R0 : 0x000007E4
R1 : 0x00000107
R2 : 0x00545C8C
R3 : 0x000007E4
R4 : 0x00540298
R5 : 0x00545F48
R6 : 0x00000000
R7 : 0x00545D60
R8 : 0x00000000
R9 : 0x00000000
R10 : 0x00544808
R11 : 0x00000000
R12 : 0x00002008
LR : 0x004C8B7E
Test - 3
start_ap "tester" wpa2 "1234abcd" 52 20 192.168.1.2 255.255.255.0
In this case channel i selected 52 with 20 MHz bandwidth
I can see RF output after around 1 minutes of when i received the last response. Maybe because of DFS in this case. Below is the log info
Bandwidth : 20
calling chanspec IOVAR with chanspec=d034 channel=52
Regards.
For HT40, please choose channel 38,46,54,62 mid: 102,110,118,126,134,142 or high band: 151, 159
As you mentioned i tested AP with channel 38,46,54,62 mid: 102,110,118,126,134,142 or high band: 151, 159
38 = no issue, can able to see RF beacon after starting AP.
46 = no issue, can able to see RF beacon after starting AP.
54 = issue, can't get RF out after starting AP, takes 1 minute time to get RF beacon.
62 = issue, can't get RF out after starting AP, takes 1 minute time to get RF beacon.
102 = issue, can't get RF out after starting AP, takes 1 minute time to get RF beacon.
110 = issue, can't get RF out after starting AP, takes 1 minute time to get RF beacon.
118 = issue, can't get RF out after starting AP, takes 1 minute time to get RF beacon.
126 = issue, can't get RF out after starting AP, takes 1 minute time to get RF beacon.
134 = issue, can't get RF out after starting AP, takes 1 minute time to get RF beacon.
142 = issue, can't get RF out after starting AP, takes 1 minute time to get RF beacon.
151 = no issue, can able to see RF beacon after starting AP.
159 = no issue, can able to see RF beacon after starting AP.
May i know why, you mentioned for HT40 only can use channel 38,46,54,62 mid: 102,110,118,126,134,142 or high band: 151, 159
Because the channel map for 40 MHz bandwidth contain much more other channels, what happen with those channel?
The channels i mentioned issue above, DFS is enable (i think so), how can i disable DFS?
For channel you can try different country for a test, 5G channels should have more limitions like DFS you said .
I am using country set as US
channel 34 is also under HT40 setting, but why i am getting error?
How can i disable DFS? we are doing conducted test under RF shielded environment.
Regards.
I see the lowest channel is 36. and RF tests should use MFG test app and commands list , not suggest you to do such test by changing normal firmware.
If you look into channel spec list, channel 34 is a valid channel with HT40.
Can you send me the list of channel document this chipset support?
I am also looking for disabling DFS. can you provide me information for that.
so, there is no way we can bypass DFS?
hello:
We have a detailed description in the document , not easily to tell you the steps.
so need your help to check the document in detail.
hi,
then let me go through the document you provided and get back to you in a day or so.
regards
hi,
i am not using non signaling or test mode. i am looking for DFS disabling method, from document what i found as per below.
wl dfs_preism 1 // To enable and disable the CAC (60sec). 0 = disable, 1 = enable
wl radar 1 // Enable radar detection
wl dfs_ism_monitor 0 // To enable and disable the channel from moving when radar signal is detected. 0 = enable, 1 = disable
Now all above command only can run using wl exe. but, when i set AP by signaling mode for example, if i create a simple application, where i call starting AP, how can i execute those command? can you guide me, where i can get those api? so i can call inside my code.
wwd_wifi_set_iovar_value( IOVAR_STR_*, 1, WWD_STA_INTERFACE);
you can have a try with this api..
change the IOVAR_STR* and its value to the one you want . better to find a good position to change the value.
some commands need a down and up sequence to make it work.
wwd_result_t wwd_wifi_set_down( void )
wwd_wifi_set_iovar_value( IOVAR_STR, 1, WWD_STA_INTERFACE);
wwd_result_t wwd_wifi_set_up( void )
Thanks. I managed to make it work now.
I have one more question. This radio chip set support power range from -31 to +31 dBm. using tx power API i can't set anything below 0 dBm. May i know why? when i look into low level functions, i found internally the value what i set get multiplied by 4 and write to network processor.
Can you provide me some detail information on this?
Regards.
I only can get this command explanation from document:
Use this command to change the power in real time. Can also use the quarter step
command wl txpwr1 -o -q XX, where XX is any value between 0 to 100.
What is the unit? I am looking for dBm unit.
Regards.
the unit is dbm .
hi,
so, it's support from 0 to 100 dBm?
regards
Multiply the number with 1/4 will be the actual dbm value.
hi,
sure, i will try this.
but can you tell me this 0 to 100 map to what power level in dBm?
they all looks like positive number. am i right? so, below 0 dBm, we can't set it.
Yes, I can't find the interface also.
