CYW54907 is fully compatible (also pin to pin) from CYW43907
MaFa_974161
100 sign-ins 50 replies posted 50 questions asked
Hello.
I see on you site that is available the new CYW54907 processor.
I have developed I firmware for the "old" CYW43907 processor and my collegue is drawing the board schematics.
The new processor if fully compatible from the old ?
Can I use the same firmware (obviously I compile this for CYW54907) ?
Charles_Lai
250 sign-ins 10 likes given 10 questions asked
You can migrate your application to the new platform without much modification. But you need to re-generate your firmware depending on CYW54907.
CYW54907 has many features in common with CYW43907. So it's possible to upgrade from CYW43907 to CYW54907.
Charles_Lai
MaFa_974161
So I have just to create the new "Make Target" file based on CYW954907 ... right ?
Charles_Lai
Basically, you can use the Library Manager to manage the BSPs you are using. BSP and the application code are designed to be disjunct for better code migration.
To find detailed information on what is BSP, downloading new BSPs, and changing the active BSP, see:
https://www.cypress.com/file/520271/download
Actually I'm using WICED studio ... not Modus Toolbox.
I downloaded Modus Toolbox but I don't know how to create project for my  CYW954907.
