Hi All,
When I did iperf in STA mode in 5G, I was able to get 130 Mbps (UDP) with a PC on Ethernet.
I would like to know if there is any known performance hit if I config the 43907 in AP mode (5G), and have a tablet join the 43907 soft-AP, and make a UDP connection from 43907 to the tablet.
Will I be able to obtain at least 32 Mbps for such connection? There is no other device joining the AP.
WICED Studio Wi-Fi Combo
The throughput can be impacted through various parameters. Mostly, it's the environment where you're setting your setup. It depends on the no. of devices joining the AP, noise, interference, distance from the client device to the AP, packet loss, etc..
I would suggest that you carry out the test and then can configure/change the required parameters to get the specified throughput.
Aditi
I'll confirm with the internal team and will revert back
Aditi
Hi Aditi,
Do you have any update information?
Will I encounter any throughput impact when I run in AP mode, while there is only one connection?
Aditi
