Dear Cypress Community,
If somebody has a Wi-Fi Dongle Reference Design for CYW43907?
Thank you!
Hi Ivan,
Currently, we don't have a reference design for such an undertaking. I am assuming that by Wi-Fi dongle you meant configuring the device as a client(STA) that receives packets from an AP connected to the internet. And the device will be connected to the system using a USB interface(correct me if i am wrong). You could make use of the snip application: https_client and https_server to understand how to use the https APIs. The 43907 does support USB 2.0 and the device drivers could be found at
/43xxx_Wi-Fi/WICED/platform/MCU/BCM4390x/peripherals/usb_device
in the WICED SDK. Although the USB Stack APIs (USB stack source)are not made public. /43xxx_Wi-Fi/libraries/drivers/USB/./.
Hi Ivan,
Hi vnak,
could you give me step-by-step instruction for attaching the usb_device library to empty project (which files I have to add in make file, which sources and so on)?
