Wi-Fi Combo
hibh_4839301
New Contributor II
I want to program my CYW43907 board from Command line. Currently I can only program using Wiced Studio. But, In we need to program multiple devices. So, I am looking for way to program the device using command line script.
Can anyone suggest me, how can I program CYW43907 from command line.
Hiren
MuraliR_36
You could use the same makefile script from the command line and try flashing the device.
You could also try using the sflash_write.tcl script as mentioned in this blog post https://community.cypress.com/t5/Resource-Library/How-to-use-sflash-write-tcl-script-embedded-in-WIC...
MuraliR_36
