I am currently designing a wireless VOIP-like product based on the 43907 MCU.
Reviewing the audio libraries/drivers, I found out a worrying comment in the I2S platform driver (platform_i2s.c):
/* FIXME Revisit when full-duplex is fully implemented! */
static inline void I2S_LOCK_PORT( platform_i2s_port_t port ) {
(void)0; /* TODO */
Does it mean that I should not use the audio API in a multi-threaded application (with one TX thread and one RX thread) ?
What about a single thread application ?
As far as I know, there is no mention of such limitation in the documentation.
For now, I patched the WICED audio module to allow async IO and managing the full duplex transactions in a single thread (without any wiced_audio_wait_buffer() blocking call).
But is this enough ?
Thank you for your help.
I2CI2S
Wireless MCU
CYW43907 I2S hardware supports full-duplex communication but the driver for that is not completely developed which is why you can see the comment mentioned in platform_i2s.c.
If you have already allowed async IO and can manage the full duplex transactions, I believe that should be enough.
