Wi-Fi Combo Forum Discussions
SeVo_4684381
First like given Welcome!
Does Ethernet module of Cypress WiFi MCUs support MAC (RMII) to MAC (RMII) connection without Ethernet PHYs?
As I want to use Ethernet for onboard communication with FPGA, I want to avoid extra chips on the PCB.
Thank you in advance.
YashM
First question asked 250 sign-ins 100 replies posted
Ideally, RMII connections are meant for communication between MAC and PHY. If you see the schematic of CYW43907EVAL1F, there is a PHY chip being connected externally (BCM524), which gets connected to RMII pins of CYW43907.
You can check the driver code of ethernet in C:\Users\<name>\WICED-Studio-6.6\43xxx_Wi-Fi\WICED\platform\MCU\BCM4390x\peripherals\ethernet. We haven't tested the MAC to MAC communication through RMII.
YashM
Please have a look at the following blog post for your reference Application for Network Interface through Ethernet with CYW943907AEVAL1F
YashM
Thank you for clarification!
