ShKa_4260991
Hi Cypress member,
I was asked about how do we modified CCA/ED configuration by our customer.
In Nvram file for Murata Type1MW(CYW43455), the following two items are written.
ed_thresh2g=-65
ed_thresh5g=-65
Can we modified them and what can we see as a result?
Shohei.
GauravS_31
250 solutions authored 250 sign-ins First comment on KBA
For dual band radios, you can consider using the following values for energy detect to pass adaptivity if using production firmware:
ed_thresh2g=-70
ed_thresh5g=-73
Alternately, if you are using mfgtest firmware, you can manually set the threshold level using wl phy_ed_thresh X where X is between 0 to -75.
GauravS_31
ed_thresh2g=-70
ed_thresh5g=-73
