DS_Lin
Distributor - Zenitron(GC)
100 replies posted First comment on blog 100 sign-ins
Hi Sir,
The development environment is based on Wiced SDK6.2.1
For the PAIRING_MODE issue, we have test and detail information and project list is in below, could you help to check?
After tested, SDK seems doesn`t support WICED12 for enable PAIRING_MODE,
Because the error message is mean : no function for wiced12 to execute pairing mode (no include file).
tried to add include function to wiced12 as below figure, and  it can  not compiler/warning download to module.You can see the compiler failed in the attached files about JPG ,TKS!
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hi DSli_3988276​,
To make wiced_bt_set_pairable_mode(), you have to define WICED_SET_BT_PAIRABLE_MODE flag.
But as mentioned in ble_wifi_introducer.mk, WICED_SET_BT_PAIRABLE_MODE is not supported for CYW4343W chips. It is only supported for CYW207x9 based chips.
SheetalJ
Hi DSli_3988276​,
DS_Lin
Hi Sheetal,
If I want to use this feature (Wiced_bt_set_pairable_mode),
have to change CYW4343W into CYW207x9  based chips?
DS LIN
SheetalJ
Hi DS Lin,
CYW4343W is a WiFi-BT combo chip, CYW207x9 (lets say CYW20719: CYW20719 Product Guide) is a Bluetooth chip. Both has different functionalities and cannot be interchanged.
DS_Lin
Hi Sheetal,
Thanks for your prompt reply.
But I still need to have a discussion with you,
WICED_SET_BT_PAIRABLE_MODE is not supported for CYW4343W chips. Really? Thanks.
DS LIN
SheetalJ
Yes, WICED_SET_BT_PAIRABLE_MODE is not supported for CYW4343W chips.
