user_4237101
First like given
LG G4 use CYW4339 chip to WiFi and Bluetooth...It works really fine with Android Lollipop or Nougat but we have problems with voice call with Bluetooth Headset, we can talk and people listen us fine but we can't listen the voice from the contact... it's like bluetooth voice is garbled / distorted / robotic
Thanks if anyone can help us
The BCM4339 integrated in the LGE G4 Phones is actually supported by Broadcom.
Please raise a request in their portal for further support.
VinayakS_26
100 replies posted 50 replies posted 25 replies posted
Could you provide some information on the SW/FW version of the BT that is present in the G4?
Which version of Android are you getting the error.?
Vinayak
Hello VinayakS_26 and really thanks to help us...!
SW/FW version: Version: 6.37.34.43 CRC: 20a798b1 Date: Tue 2016-05-24 10:32:18 PDT Ucode Ver: 855.1041 FWID: 01-96a5b4bb
Android version: 8.0, 8.1, 9.0 (worked fine in 7.x though)
Example config (changed it locally for all tests): https://github.com/Suicide-Squirrel/...16.0/bluetooth
When using I2S (SCO_USE_I2S_INTERFACE = TRUE) I can hear the other site just fine but the other site has distorted sound
When using the default PCM mode (SCO_I2SPCM_IF_MODE = 1) my site has distorted sound but the other site can hear me fine
My guess is that there might be a better chance to use I2S but then it might need adjustments in mixer_paths (https://github.com/Suicide-Squirrel/...ixer_paths.xml) which I am not sure about the how though.
it makes no diff if configured as master or slave.
I also played around a lot with sample rates, clock rates (based on the PDF I have attached here: https://github.com/Suicide-Squirrel/...ment-489588554) and such but nothing I had tried had any success. see again the comment here: https://github.com/Suicide-Squirrel/...ment-489588554 which options I played around with
user_4237101
First like given
Hello... Someone can help us pls?
