SaMo_4348011
First like given
We are working on a project using the CYW43353 device.
I would like to know if the CYW43353 device supports the Bluetooth advertiser/peripheral role.
Any response would be greately appreciated.
Sepehr
AnjanaM_61
Hi Sepehr,
CYW43353 supports Bluetooth 4.1 compatible BT classic and BLE. It will support peripheral role .
Datasheet :  https://www.cypress.com/documentation/datasheets/cyw43353-single-chip-5g-macbasebandradio-integrated...
Anjana
AnjanaM_61
Hi Sepehr,
Anjana
Hi Anjana,
Thanks a lot for your response.
Could you please point out where specifically in the datasheet I could refer to for more information about the capabilities of the device regarding the advertiser/peripheral role?
Sepehr
You may refer section 4. Bluetooth Subsystem Overview  and 5. Bluetooth Baseband Core.
However the datasheet may not be describing all the properties.
CYW43353 will support any BLE 4.1 features of advertiser/peripheral .
Anjana
