Is there a programming manual to program the Wifi module aboard the development board. We do not want to use WICED studio for programming the wifi functionality.
Are there any APIs available for the wifi module?
If you don't want to use WICED, then you would have to use Modus ToolBox 2.1(The examples in this would be limited as of now) https://www.cypress.com/products/modustoolbox-software-environment. The Documentation for this is available at Cypress Wi-Fi Connection Manager Library: Overview
You can also use either MBED: Cypress Semiconductor | Mbed or Amazon Free RTOS : Getting Started with Amazon FreeRTOS and PSoC62 + 43xxx.pdf
Please go through these and the Wi-Fi examples at Cypress Semiconductor Corporation · GitHub and you will get an idea of whats available now.
If you are just getting started with your Project/Product, then i suggest that you contact local sales and get a better idea of which product is best suited for your application and get a brief overview of how to go about things. You can find the sales offices at https://www.cypress.com/about-us/sales-offices/america
Are there low-level programming manuals available for CY4343W which is independent of an IDE or development environment.
Please go through GitHub - cypresssemiconductorco/wifi-host-driver: Embedded Wi-Fi Host Driver that provides a set of ... You need to port this to the Host processor that you are using along with the IDE/Development environment
