IDE:WICED-SDK-2.3.1
Question: Apps project, compile wwd.appliance-BCM943362WCD4 download run, prompted Apps / wwd / appliance / FreeRTOS_LwIP_appliance.c: 52:22: fatal error: lwip / opt.h: No such file or directory, as shown, which should I Makefile file, add the path opt.h header file? Please help, thank you!
It looks like your make target is trying to build with ThreadX and NetX_Duo instead of FreeRTOS an LwIP.  Try: wwd.appliance-BCM943362WCD4-FreeRTOS-LwIP download run
Thank you cgage!As you say, I compile it(wwd.appliance-BCM943362WCD4-FreeRTOS-LwIP download run) . A problem has been solved, but appear as shown in the figure below, this is a DEMO routines, compile all cannot pass, Makefiles path problem a lot, the SDK is not perfect, like this kind of situation should be how to modify which Makefiles in the file?opt.h找不到路径 2.jpg
Which SDK version are you using? Did you try to run 'make clean'? I can't reproduce your issue using SDK 2.4.1.wwd_appliance.PNG
GregG_16
50 sign-ins 25 sign-ins 25 comments on KBA
Have you resolved this or is this still an issue?
GregG_16
I'll assumed this is answered, but please reopen a discussion if needed?
