Wi-Fi Combo Forum Discussions
agmi_3321141
Level 4
Level 4
Hi!
My build console is not producing the correct map for flash memory (please see attached log). The map csv file in the build folder has blank contents under "memory area" for all flash contents. This ends up making the flash column count zero in the console.From the "address" column I know it is going to internal flash. Any ideas on fixing this?
Can you replace the map_parse_gcc.pl file attached with this mail in your WICED and try the build?
Also please let me know your WICED version.
PriyaM_16
25 solutions authored 10 solutions authored 5 solutions authored
Can you please mention the platform and attach the platfrom makefiles for reference?
I observe this behavior for other platform builds on the IDE too, so I am not sure if it is platform dependent? For example one of the default on the IDE is - "snip.scan-BCM943362WCD4-FreeRTOS-LwIP-SDIO". also gives me a similar build map.
Thanks for the updated perl script. I can see the map on the console now.
My WICED version is: "Wiced_006.001.000.0085"
