ew
First like received Welcome!
Hi
The Ethernet interface doesn't get any data, in this two apps:
test.console-CYW943907AEVAL1F download run
and
snip.ping_ethernet-CYW943907AEVAL1F download run
In the WICED Studio 6.0.1.5 the Ethernet interface works perfect with the two apps !!!
Cypress, please give us a workaround, or tell us when the next WICED Studio version will be released !
CC
RaktimR_11
We are already aware of this issue which occured because of the NetX/NetX_Duo NS stack upgrade.
Workaround: Don't reinitialize the DHCP in wiced_network.c for the NS you are using. For 6.1.0.85,  comment out the line nx_dhcp_reinitialize( &DHCP_HANDLE( interface ) ); in wiced_network.c (line #1266) for your NS. You should be able to see the ethernet interface up and running.
RaktimR_11
ew
Hi Roy
Thanks, it works with your workaround
Do you have a release schedule for the next WICED-Studio release ?
CC
RaktimR_11
Please check this threadWICED Studio error message for the release schedule.
MichaelF_56
We are planning to release WICED Studio 6.2 in the Mid-May time frame.
