Bi-directional WICED USB Serial Port
I am using the Avnet AES-BCM4343W eval board and our project requires that the serial debug port be bi-directional.
Does the "WICED USB Serial Port" support bi-direction or is it output only from an eval board.
If it does support 2-way communication where/what is the api for the board to receive data from the serial port?
If it does not support 2-way communication can the code be modified to do so?
-Matt
Yes this is a fully bidirectional port
Lol at the sample console or uart applications in the sdk
You can find the libraries for it in library->utilities->command_console
