01:41 AM
Sep 19, 2013
01:41 AM
I noticed that, in linux brcm wifi driver, structure bdc_header defined as below:struct bdc_header { uint8 flags; /* Flags */ uint8 priority; /* 802.1d Priority 0:2 bits, 4:7 flow control info for usb */ uint8 flags2; uint8 rssi;};but in wiced implementation,bdc_header defined as :typedef struct{ uint8_t flags; /* Flags */ uint8_t priority; /* 802.1d Priority (low 3 bits) */ uint8_t flags2; uint8_t data_offset; /* Offset from end of BDC header to packet data, in 4-uint8_t words. Leaves room for optional headers.*/} sdpcm_bdc_header_t;The last member is changed to data_offset, it is bad .RSSI is very important information, where can I find this info instead?
Labels
SPI
- 4-uint8_t
- 802.1d
- bdc_header
- bits
- brcm
- change
- changed
- control
- data
- data_offset
- defined
- driver
- find
- flags
- flags2
- flow
- header
- headers.
- implementation
- important
- info
- information
- leaves
- linux
- member
- noticed
- offset
- optional
- packet
- priority
- room
- rssi
- sdpcm_bdc_header_t
- struct
- structure
- typedef
- uint8
- uint8_t
- wiced
- wifi
- words
03:34 PM
Oct 13, 2013
03:34 PM
03:34 PM
Oct 13, 2013
03:34 PM
Whats wrong with using the wiced_wifi_get_rssi() API call?
Apr 04, 2014
07:50 PM
Apr 04, 2014
07:50 PM
Is this still an issue?
02:37 PM
Jun 15, 2015
02:37 PM
Discussion is being locked. If you have any follow-up, please start a new discussion.
