I am working with a CYW4343W and WICED Version: Wiced_006.004.000.0061
My Central application is behving as expected for most of the time, scanning for and connecting to a BLE Server, performing Service and Characteristic discovery, writing to the Server's CCCD, pairing and bonding etc. However, if I leave it to run for a few hours it will intermittently receive the BLE management callback event BTM_ENABLED_EVT with a value of WICED_TIMEOUT for p_event_data->enabled.status.
I have found that ignoring these WICED_TIMEOUT events ultimately results in one the of subsequent calles to a WICED BLE API function such as wiced_bt_gatt_send_discover() etc not returning, after which my application will hang awaiting the API call to return.
My short-term solution is to reset my device whenever the application receives BTM_ENABLED_EVT with a value of WICED_TIMEOUT. However, I would like to know what is the recommended procedure for handling such errors, please?
Also, what are the most likely causes of the BTM_ENABLED_EVT with a value of WICED_TIMEOUT, please?
R
WICED Studio
Wifi+Bluetooth
For record, WICED_TIMEOUT error is generated by stack when it doesn't get response from controller chip for some command.
Closing this thread as further discussion is going on in a technical case.
Can you please share your application code and steps to reproduce the issue at our side?
Anjana
Hello Anjana,
Unfortunately, it would be very difficult for me to publicly share our source code. Please could you give general answers to my questions:
- What is the recommended procedure for handling BTM_ENABLED_EVT with a value of WICED_TIMEOUT, please?
- What are the most likely causes of the BTM_ENABLED_EVT with a value of WICED_TIMEOUT, please?
Rob
@AnjanaM_61
Are you able to answer my questions, please?
Rob
Dear @AnjanaM_61 ,
Please could you respond to my questions.
Rob
Hi Rob,
Sorry for missing to update your thread.
Without finding the root cause , it will be difficult to recommend any work around.
Is it a BT only application which you are testing or any parallel wifi operation is running ?
WICED_TIMEOUT might have resulted from any of the pre BT activity. We need to figure out which exact API / BT activity is triggering the timeout . That's why we need the application to check the code flow.
1. My first suggestion is to check if this issue is happening in WICED 6.6 or not. As there was some known bugs with WICED 6.4 and its fixed in WICED 6.6 . If you still see the issue , then
1. If possible, share a simplified code to reproduce the issue at our side.
2. Can you please check the API results of all functions are success or not in your application? From that you may get an idea if any function is not executing correctly.
3. Can you share the device debug logs / airlogs if possible ?
4. Which peer device (server) you are using for the test ? Is it 4343W itself or any other peer apps or third party ?If then , did you try with any other BLE server devices ?
5. Are you seeing wiced_bt_gatt_send_discover getting hang often ? What is the connection parameters you are using? Can you modify the connection interval , supervision timeout values and see if it helps to resolve the issue?
6. Can you please confirm if you are using enough buffer pools in wiced_bt_stack_init ? Refer hello_client example for wiced_bt_cfg_buf_pools default values
7. Are you using 4343W EVAL board or custom board ?
Thanks & Regards,
Anjana
@AnjanaM_61 wrote:
Hi Rob,
The CHANGELOG.txt in 6.6.0 only mentions:
* Updated Bluetooth firmware for 4343x and 43340 platforms
* Included some defensive code to prevent attacks similar to ones described in the Sweyntooth vulnerabilities
* Fixed BT + Wi-Fi combo chip security vulnerabilities collectively known as Spectra attack (CVE-2019-15063, CVE-2020-10367 and CVE-2020-10368)
i.e. The 6.6.0 changelog does *not* mention such know bugs, so can you list the known bugs.
@AnjanaM_61 wrote:
Hi Rob,
It means the user needs to handle WICED_TIMEOUT by different use case?
So what do you expect the users to do if got WICED_TIMEOUT?
Hi @AxLi_1746341 ,
Ideal way to deal with such error would be to find the root cause of the issue and then try to resolve that. As @AnjanaM_61 suggested above,
1. @RoHe_4370821 can try checking if he is getting Success for every API used.
2. You can try debugging and see where exactly you are getting the Timeout error.
3. Check if there are any simultaneous BT or other activities running.
Getting WICED_TIMEOUT is not a bug; it is an error occurred while running an application. Therefore, we cannot add it in known bug list.
@SheetalJ wrote:
Hi @AxLi_1746341 ,
I'm not asking add it in known bug list.
It's @AnjanaM_61 mentioned that "As there was some known bugs with WICED 6.4 and its fixed in WICED 6.6.".
So I want to know what was fixed because the 6.6 changelog does not mention it at all.
Hi @SheetalJ ,
In response to your suggestions,
We already do this and our application will report any errors. But, I will double-check we have not missed anything.
I shall provide some evidence to you ASAP with debug logs, traces etc.
May I ask: What simultaneous activities would be illegal when we are running with a BT scan or connection, please? Are you able to direct me towards documentation that describes these things?
That is good to know that it is an error rather than a bug in the stack. I'm hoping that my application is simply doing something illegal and that we may get to the bottom of it and find a solution.
Thank you.
RH
Hi @AnjanaM_61 ,
Thank you for responding to my query.
In response to your questions:
We are using the 4343W with BT and WiFi. May I ask: Are there any rules about how we manage both radio interfaces in parallel? Perhaps we are doing something illegal. Where may I find documentation regarding concurrent BT and WiFi use, please?
I understand and thank you for the offer to examine our source code. However, we would need to arrange with our respective legal teams to provide an NDA before we could consider this. This could take some time to provide, but may be an option if we cannot find another solution. Perhaps we could revisit this if we are unable to resolve it another way.
At this moment in our development cycle, we do not have the resources to perform an upgrade to WICED 6.6 as we are under pressure to deliver. I need to resolve our issues with WICED 6.4, or find acceptable work-arounds. An upgrade to WICED 6.6 would be a last resort.
Again, we are time-pressured due to a need to deliver. If all else fails, perhaps we will have to spend the time to develop a simplified version and see what we can understand from this. However, without the behaviour of our existing application we may not see the issue. So, this could result in a lot of time spent without conclusion. I won't rule it out, but hope we can find a faster approach.
It is our policy to check for and report ALL return values for errors throughout our project. Of course, it is possible we have missed one and we will check this.
Yes, I will capture some logs to share with you in the near future. I'll come back to you with these ASAP.
Our 4343W device is acting as both Client and Server simultaneously. The issues seem to be only occurring with the Client code as far as I can tell. We use an Adroid device to connect to the Server to read/write characteristic values. We have two third-party custom bluetooth equipment that we connect the Client to: One is a Beacon and we are using the wiced_bt_ble_observe() to scan for its advertisements; The other is a discoverable sensor and we are using the wiced_bt_ble_scan() to scan for it.
Sometimes the wiced_bt_gatt_send_discover() hangs, sometimes it is wiced_bt_gatt_le_connect(). I could alter and experiment with connection intervals and supervision timeout values if you feel strongly that this could cause such issues. However, I would not expect the stack to hang due to non-optimal values for these parameters, unless there were a known bug in the stack.
Yes, we have focussed on the buffer pools in the past as we did previously have issues with insufficient buffer pools. I am as sure as can be that our buffer pools are sufficient. However, other than printing out the buffer pools usage with wiced_bt_print_cfg_buf_pool_stats() and checking for the "GKI_exception out of buffers" message, I'm not sure what else can be done to verify this? Certainly I have seen that if I call wiced_bt_print_cfg_buf_pool_stats() from a timer callback after the issue of non-returning WICED API function has happened, the buffer pools printout is showing there are available buffer pools.
We are using our own custom-designed board.
Thank you again and I hope that after reading my responses above, that you will have some more suggestions. Meanwhile, I will collect some debug logs over the coming days to share with you.
RH
A technical case is created to discuss this issue further.
