On a bcm9wcd5eval1_3 , using ble_proximity_reporter as a base, I added my own services and characteristics to
const uint8_t gatt_db[] = {
I have added 1 service with 2 read/write chars and 1 notify char.
If I try to add a 3rd read/write char, it does not show up in the in the discovered services/chars
If I move the 3rd read/write char above the notify, the new char shows up but the notify does not.
Is there some upper limit or define that allows only a certain number of services/chars to be defined.
Sajid
What do you use as a client?
If you use Android phone, number of characteristics may be limited.
It looks over 32 characteristics doesn't work well.
Please check how many characteristics in your gatt_db.
