I'm using the BCM943907 chip and I was wondering how does the background connect work.
There is not much documentation regarding wiced_bt_gatt_le_connect, wiced_bt_ble_set_background_connection_type and wiced_bt_ble_update_background_connection_device.
I tried all possible combination of the three functions above but I never receive the wiced_bt_ble_selective_conn_cback_t registered by wiced_bt_ble_set_background_connection_type.
Could you please clarify how to use background connection and its mechanism?
Thank you.
hello:
in the introduction:
* @param[in] p_select_cback: callback for BTM_BLE_CONN_SELECTIVE
and I have a test , output one log, and steps are below:
1. use demo_hid_host to do a test based on 20706 evb .
2. add callback function, modify to BTM_BLE_CONN_SELECTIVE but missed parameter and not know if the return is correct.
3. connect a hid mouse, then move the mouse battery, power on the mouse again, the log showed.
please have a check.
