Wi-Fi Combo
user_2112781
10 likes received 10 likes given 5 likes given
I'm using the BCM943907 chip and I was wondering how does the background connect work.
There is not much documentation regarding  wiced_bt_gatt_le_connect, wiced_bt_ble_set_background_connection_type and wiced_bt_ble_update_background_connection_device.
I tried all possible combination  of the three functions above but I never receive the wiced_bt_ble_selective_conn_cback_t registered by wiced_bt_ble_set_background_connection_type.
Could you please clarify how to use background connection and its mechanism?
Thank you.
Zhengbao_Zhang
Moderator First comment on KBA 10 questions asked 5 questions asked
hello:
  in the introduction:
  * @param[in] p_select_cback: callback for BTM_BLE_CONN_SELECTIVE
and I have a test , output one log, and steps are below:
1. use demo_hid_host to do a test based on 20706 evb .
2.  add callback function, modify to  BTM_BLE_CONN_SELECTIVE but missed parameter and not know if the return is correct.
3.  connect a hid mouse, then move the mouse battery,  power on the mouse again, the log showed.
please have a check.
Zhengbao_Zhang
Hello:
just a remind,  43907 is a wifi only chip.
user_2112781
Yes, sorry I forgot to mention the BLE chip, it's a  BCM20707.
Zhengbao_Zhang
hello:
