I am using inventek system usb dogle ISM43341 - USB with wiced sdk 3.1.2. Tested bt_smartbridge app which works in central mode. Also gone through all sdk to look for ble app/api's working in peripheral mode; but unable to find out. Can I get ble library /api's which works in peripheral mode?
SPI
Note that the new WICED SDK 3.3.1 SDK supports peripheral mode via a sample application called ble_proximity_reporter.
The current WICED SDK does not support BLE peripheral mode.
Thanks for the reply. When should I expect support for BLE peripheral mode( How much time it will take)? Because our application requires that.
The BLE stack to be included in WICED SDK 3.3.1 will be a full featured dual mode stack which supports all possible roles and flavors.
The release is at least a quarter out.
