Hi Sir,
Currently, we study to bring up the BCM94343WWCD2 platform on Wiced Studio 5.x. When make target " snip.scan-BCM94343WWCD2-ThreadX-NetX download download run", there is no Wifi scan information.
Starting WICED v5.0.0
Platform BCM94343WWCD2 initialised
Started ThreadX v5.6
Initialising NetX v5.5_sp1
Creating Packet pools
Waiting for scan results...
# Type BSSID RSSI Rate Chan Security SSID
If the wiced studio change to 4.x version, it's workable. We would like to know if BCM94343WWCD2 platform is ready on Wiced Studio 5.x.
Wifi+Bluetooth
There is no public changelog for the wlan firmware.
Only cypress can give you suggestion.
Small note its ok in your make string double "download download"? Maybe you wanted write "download_apps"?
BR
Darius
Sorry, typo!
Update
17:39:19 **** Build of configuration Default for project 43xxx_Wi-Fi ****
"D:\\WICED_SCR\\WICED-Studio-5.0\\43xxx_Wi-Fi\\make.exe" snip.scan-BCM94343WWCD2-ThreadX-NetX download run
MAKEFILE MAKECMDGOALS=snip.scan-BCM94343WWCD2-ThreadX-NetX download run OTA2_SUPPORT is disabled
Building Bootloader
Finished Building Bootloader
| | Static |
Module | Flash | RAM |
App | 404 | 0 |
crc | 1060 | 0 |
Host MCU-family library | 13261 | 2489 |
Interrupt Vectors | 388 | 0 |
libc | 23769 | 3064 |
Networking | 850 | 9787 |
NetX | 3566 | 40 |
Packet Buffers | 0 | 22360 |
platform | 1168 | 256 |
RAM Initialisation | 2364 | 0 |
resources | 384268 | 0 |
Ring_Buffer | 112 | 0 |
Startup Stack & Link Script fill | 6 | 1 |
ThreadX | 7936 | 396 |
TLV | 28 | 0 |
WICED | 3984 | 1056 |
WWD | 16708 | 3111 |
TOTAL (bytes) | 457508 | 42560 |
Downloading Bootloader ...
Download complete
Downloading DCT ...
Download complete
Downloading Application ...
Download complete
Resetting target
Target running
Build complete
Making .gdbinit
17:39:58 Build Finished (took 39s.287ms)
Starting WICED v5.0.1
I see, that your "resources" are 384268 size.
So, you try use firmware in internal flash?
It seems to me, that you must be sure, that firmware are loading from internal flash, but not from external spi flash. (Maybe best way are debug code or check load time from internal flash it must be fasted).
WIFI firmware are different in SDK5 and SDK4. (at external spi flash firmware are loaded at factory- so it can be old and maybe not working with new SDK).
To load in to external flash firmware need in make string add download_apps.
BR
Darius
Hi Sir,
Yes, we use firmware in internal flash for first testing. After try to add target "download_apps", the result is same.
D:\\WICED_SCR\\WICED-Studio-5.0\\43xxx_Wi-Fi\\make.exe" snip.scan-BCM94343WWCD2-ThreadX-NetX download download_apps run
MAKEFILE MAKECMDGOALS=snip.scan-BCM94343WWCD2-ThreadX-NetX download download_apps run OTA2_SUPPORT is disabled
Building Bootloader
Building Serial Flash Loader App
MAKEFILE MAKECMDGOALS=waf.sflash_write-NoOS-BCM94343WWCD2-SDIO OTA2_SUPPORT is disabled
| | Static |
App | 0 | 21126 |
Host MCU-family library | 0 | 13236 |
Interrupt Vectors | 0 | 388 |
libc | 0 | 548 |
platform | 0 | 1156 |
Ring_Buffer | 0 | 40 |
SPI_Flash_Library_BCM94343WWCD2 | 0 | 968 |
Startup Stack & Link Script fill | 0 | 486 |
WWD | 0 | 188 |
TOTAL (bytes) | 0 | 38136 |
Build complete
Finished Building Serial Flash Loader App
| | Static |
App | 404 | 0 |
crc | 1060 | 0 |
NetX | 3566 | 40 |
TLV | 28 | 0 |
Building apps lookup table
No changes detected
Downloading DCT ...
No changes detected
No changes detected
Downloading apps lookup table in wiced_apps.mk ... build/snip.scan-BCM94343WWCD2-ThreadX-NetX/APPS.bin @ 0x0000 size
Resetting target
Target running
Build complete
Making .gdbinit
09:47:45 Build Finished (took 17s.59ms)
ken6 wrote:
Hi Sir,
Your WLAN Firmware is not loaded, that is why scan get no result.
Hi alex,
lt's workable on sdk4.x,what's different between sdk4 and sdk5?
BR
ken
Hi, Ken
I think, that first need test in sdk5 "original" system configuration. (wifi firmware load from external flash).
So disable load wifi firmware from internal flash, because , like Alex say, "Your WLAN Firmware is not loaded" into external flash. Only I see:
because this file are loaded, then you external flash information are lost (because not found and not write WIFI firmware, address off wifi sector and size are write in lookup table at start off external spi flash )
#WIFI_FIRMWARE_IN_SPI_FLASH = NO
WIFI_FIRMWARE_IN_SPI_FLASH = YES
After need do "clean" and repeat your build/test
"snip.scan-BCM94343WWCD2-ThreadX-NetX download download_apps run"
If this not work, then need ask wiced team or community with BCM94343WWCD2 board, to test on SDK5.
BR
Darius
sqlsql_2244756 wrote:
Hi, Ken
BR
Darius
AFAICT, it should work out of box if the platform code was working in sdk-4.x.
Otherwise, it means cypress breaks something in new sdk without any note.
I have tested the platform with snip application and it is working. Can you please tell me whether you made any changes to the platform files(BCM94343WWCD2) in WICED5.x? test the snip app without modification and let us know.
Notice at your platform mk file:
Original;
BT_CHIP_XTAL_FREQUENCY := 26MHz
Modified
BT_CHIP_XTAL_FREQUENCY := 37_4MHz
Is it Ok?
BR
Darius
sqlsql_2244756 yes,It worked on SDK4.x base on our circuit design.
ken6 wrote:
Hi alex,
BR
ken
Sorry I don't work for cypress, you should ask cypress about this.
Providing both sdk4 and sdk5 boot logs for cypress should be helpful to clarify the issue.
This runs on SDK4 and works well.
Starting WICED v4.1.1
Initialising NetX_Duo v5.7_sp2
WWD SDIO interface initialised
WLAN MAC Address : B0:38:29:B8:A5:63
WLAN Firmware : wl0: Jan 10 2017 19:57:03 version 7.45.98.6 (r663489) FWID 01-cf6f763a
0 Infra D0:17:C2:03:C8:4C -97 72.2 1 WPA2 AES PSK My ASUS
1 Infra 00:24:6C:F4:56:B1 -87 54.0 1 Open SpilVIP
2 Infra 00:24:6C:F4:56:B0 -86 54.0 1 WPA2 Mixed PSK SpilGlobal
3 Infra 24:92:0E:00:EF:58 -76 72.2 6 WPA2 AES PSK CueMei
4 Infra 00:24:6C:EB:77:E0 -76 54.0 6 WPA2 Mixed PSK SpilGlobal
5 Infra 8C:DC:D4:BB:E8:77 -91 58.5 10 WPA2 AES PSK HP-Print-77-Photosmart 5520
6 Infra 2C:8A:72:B6:CC:7C -83 72.2 11 WPA2 AES PSK
Scan complete in 489 milliseconds
"D:\\WICED_SCR\\WICED\\WICED-Studio-4.1\\43xxx_Wi-Fi\\make.exe" snip.scan-BCM94343WWCD2 download download_apps run
MAKEFILE MAKECMDGOALS=snip.scan-BCM94343WWCD2 download download_apps run OTA2_SUPPORT is disabled
Building Bootloader
| | Static |
App | 0 | 21126 |
Host MCU-family library | 0 | 13220 |
libc | 0 | 548 |
platform | 0 | 1140 |
WWD | 0 | 188 |
TOTAL (bytes) | 0 | 38104 |
Build complete
| | Static |
App | 404 | 0 |
crc | 1060 | 0 |
Host MCU-family library | 15455 | 2605 |
libc | 23453 | 3064 |
Networking | 1001 | 8523 |
NetX-Duo - Interfaces & Stacks | 0 | 16 |
Other | 3678 | 92 |
Packet Buffers | 0 | 23088 |
platform | 1244 | 256 |
RAM Initialisation | 2332 | 0 |
SPI_Flash_Library_BCM94343WWCD2 | 512 | 0 |
Startup Stack & Link Script fill | 11 | 1 |
ThreadX | 7864 | 396 |
TLV | 28 | 0 |
WICED | 3899 | 976 |
WWD | 15503 | 3067 |
TOTAL (bytes) | 74612 | 42084 |
No changes detected
Downloading DCT ...
No changes detected
No changes detected
Downloading WIFI_FIRMWARE ... at sector 1 size 94...
Downloading apps lookup table in wiced_apps.mk ... build/snip.scan-BCM94343WWCD2/APPS.bin @ 0x0000 size
Resetting target
Target running
Build complete
Making .gdbinit
14:41:06 Build Finished (took 1m:19s.16ms)
Hi Sir,
Now is workable after replace "WICED_SCR\WICED-Studio-5.0\43xxx_Wi-Fi\resources\firmware\4343W" from SDK4.x, but i don't know if it have any side-effect.
WLAN Firmware : wl0: Jan 10 2017 19:57:03 version 7.45.98.6 (r66 3489) FWID 01-cf6f763a
WLAN CLM : API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImpo rt: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.8.4 Inc Compil er: 1.29.4 Inc ClmImport: 1.33.0 Creation: 2017-01-10 19:46:46
0 Infra 00:24:6C:F4:56:B1 -83 54.0 1 Open SpilVIP
1 Infra 00:24:6C:F4:56:B0 -82 54.0 1 WPA2 Mixed PSK SpilGlobal
2 Infra D0:17:C2:03:C8:4C -95 72.2 1 WPA2 AES PSK My ASUS
3 Infra 24:92:0E:00:EF:58 -73 72.2 6 WPA2 AES PSK CueMei
4 Infra 00:24:6C:EB:77:E0 -83 54.0 6 WPA2 Mixed PSK SpilGlobal
5 Infra 2C:8A:72:B6:CC:7C -91 72.2 7 WPA2 AES PSK
6 Infra 8C:DC:D4:BB:E8:77 -88 58.5 10 WPA2 AES PSK
Then it's very strange.
What if you copy the wlan firmware from sdk-5 to sdk-4? Does it work?
No, it can't work. Have any suggestion?
