BCM94343W AVN debugging problem
joMa_1809706
Level 4
Level 4
10 likes received First like received First like given
I have a project based on the iot-shadow example that works. When I add the -debug to a clean build of the project and set a breakpoint at the beginning of application start the breakpoint is never tripped. The console output shows:
Starting WICED v3.5.2
Platform BCM94343W_AVN initialised
demo.aws_iot.shadow-BCM94343W_AVN-debug download download_apps
also tried
demo.aws_iot.shadow-BCM94343W_AVN-debug download download_apps run
also tried clicking debug icon after load
Any help would be appreciated.
VikramR_26
25 sign-ins 10 sign-ins 10 comments on KBA
Make sure you have removed all breakpoints to start fresh and run clean once before compiling the debug applicaiton
Kindly make sure you have added breakpoint at a valid line.
I tried debugging using the shadow application and noticed no issues.
Also request you to go over the debug settings in your debug configuration.
I said I already did that. What I want to know are the steps to setup the “debug settings in your debug configuration”.
