Hi Sir,
As SDK said, BCM943362WCD4 can support max up to 5 STA client when it is in softAP mode. But we found a strange issue see below:
1. BCM943362WCD4 has no problem support 4 STA client at the same time.
2. But when it reach at 4 STA client, the 5th STA client cannot connect to BCM943362WCD4.
3, Even we disconnect all thoses 4 STA client, the 5th STA client still cannot connect to BCM943362WCD4.
Could you pls give the suggestion? Thanks!
James
GregG_16
50 sign-ins 25 sign-ins 25 comments on KBA
This response was accidentially deleted while trying to clean up the thread.
As Nicholas Von Huben mentioned:
Due to changes in the WLAN firmware WICED-SDK-2.4.1 can only support 4 STA clients.
You may be able to support the 5th STA if you use the WLAN firmware found in SDK-2.4.0 (5.90.230.3)
GregG_16
