Hi Sir,
As SDK said, BCM943362WCD4 can support max up to 5 STA client when it is in softAP mode. But we found a strange issue see below:
1. BCM943362WCD4 has no problem support 4 STA client at the same time.
2. But when it reach at 4 STA client, the 5th STA client cannot connect to BCM943362WCD4.
3, Even we disconnect all thoses 4 STA client, the 5th STA client still cannot connect to BCM943362WCD4.
Could you pls give the suggestion? Thanks!
James
softAP
This response was accidentially deleted while trying to clean up the thread.
As Nicholas Von Huben mentioned:
Due to changes in the WLAN firmware WICED-SDK-2.4.1 can only support 4 STA clients.
You may be able to support the 5th STA if you use the WLAN firmware found in SDK-2.4.0 (5.90.230.3)
