chch_2120956
Dear,
     I want write sflash bin to external flash.(mcu:stm32f103 =>fail;stm32f205 =>ok).
     command:
   make snip.scan-BCM943362WCD2-FreeRTOS-LwIP-SPI   SFLASH=app-download
   message:
Downloading Serial Flash image
Open On-Chip Debugger 0.7.0-dev-00227-g9d47214-dirty (2013-04-16-10:43)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.sourceforge.net/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
trst_and_srst separate srst_nogate trst_push_pull srst_push_pull connect_deasser
t_srst
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
cortex_m3 reset_config vectreset
sflash_write_file
Info : max TCK change to: 30000 kHz
Info : clock speed 1000 kHz
Info : JTAG tap: stm32.cpu tap/device found: 0x4ba00477 (mfg: 0x23b, part: 0xba0
0, ver: 0x4)
Warn : JTAG tap: stm32.cpu       UNEXPECTED: 0x4ba00477 (mfg: 0x23b, part: 0xba0
0, ver: 0x4)
Error: JTAG tap: stm32.cpu  expected 1 of 1: 0x3ba00477 (mfg: 0x23b, part: 0xba0
0, ver: 0x3)
Info : JTAG tap: stm32.bs tap/device found: 0x790007a3 (mfg: 0x3d1, part: 0x9000
, ver: 0x7)
Warn : JTAG tap: stm32.bs       UNEXPECTED: 0x790007a3 (mfg: 0x3d1, part: 0x9000
, ver: 0x7)
Error: JTAG tap: stm32.bs  expected 1 of 7: 0x06412041 (mfg: 0x020, part: 0x6412
, ver: 0x0)
Error: JTAG tap: stm32.bs  expected 2 of 7: 0x06410041 (mfg: 0x020, part: 0x6410
, ver: 0x0)
Error: JTAG tap: stm32.bs  expected 3 of 7: 0x16410041 (mfg: 0x020, part: 0x6410
, ver: 0x1)
Error: JTAG tap: stm32.bs  expected 4 of 7: 0x06420041 (mfg: 0x020, part: 0x6420
, ver: 0x0)
Error: JTAG tap: stm32.bs  expected 5 of 7: 0x06414041 (mfg: 0x020, part: 0x6414
, ver: 0x0)
Error: JTAG tap: stm32.bs  expected 6 of 7: 0x06418041 (mfg: 0x020, part: 0x6418
, ver: 0x0)
Error: JTAG tap: stm32.bs  expected 7 of 7: 0x06430041 (mfg: 0x020, part: 0x6430
, ver: 0x0)
Error: Trying to use configured scan chain anyway...
Warn : Bypassing JTAG setup events due to errors
Info : Selecting JTAG transport command set.
Info : AP INIT COMPLETE
Info : stm32.cpu: hardware has 6 breakpoints, 4 watchpoints
0, ver: 0x4)
0, ver: 0x4)
0, ver: 0x3)
, ver: 0x7)
, ver: 0x7)
, ver: 0x0)
, ver: 0x0)
, ver: 0x1)
, ver: 0x0)
, ver: 0x0)
, ver: 0x0)
, ver: 0x0)
target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08000400 msp: 0x20002100
50084 bytes written at address 0x20000000
downloaded 50084 bytes in 0.689039s (70.983 KiB/s)
pc (/32): 0x20004225
Erasing Chip
Error: stm32.cpu -- clearing lockup after double fault
target halted due to debug-request, current mode: Handler HardFault
xPSR: 0x00000003 pc: 00000000 msp: 0x2000e7a0
Polling target stm32.cpu failed, GDB will be halted. Polling again in 100ms
Polling target stm32.cpu succeeded again
****************** Result: In Progress
writing 16384 bytes at 0
loadimage address 536870940 foffset 0 16384
16384 bytes written at address 0x2000001c
downloaded 16384 bytes in 0.230014s (69.561 KiB/s)
writing 16384 bytes at 16384
loadimage address 536870940 foffset 16384 16384
downloaded 16384 bytes in 0.230013s (69.561 KiB/s)
****************** Result: OK
writing 16384 bytes at 32768
loadimage address 536870940 foffset 32768 16384
downloaded 16384 bytes in 0.229013s (69.865 KiB/s)
writing 16384 bytes at 49152
loadimage address 536870940 foffset 49152 16384
downloaded 16384 bytes in 0.229014s (69.865 KiB/s)
writing 16384 bytes at 65536
loadimage address 536870940 foffset 65536 16384
writing 16384 bytes at 81920
loadimage address 536870940 foffset 81920 16384
writing 16384 bytes at 98304
loadimage address 536870940 foffset 98304 16384
writing 16384 bytes at 114688
loadimage address 536870940 foffset 114688 16384
writing 16384 bytes at 131072
loadimage address 536870940 foffset 131072 16384
writing 16384 bytes at 147456
loadimage address 536870940 foffset 147456 16384
downloaded 16384 bytes in 0.227013s (70.481 KiB/s)
writing 16384 bytes at 163840
loadimage address 536870940 foffset 163840 16384
writing 16384 bytes at 180224
loadimage address 536870940 foffset 180224 16384
downloaded 16384 bytes in 0.228013s (70.171 KiB/s)
writing 16384 bytes at 196608
loadimage address 536870940 foffset 196608 16384
writing 16384 bytes at 212992
loadimage address 536870940 foffset 212992 16384
writing 16384 bytes at 229376
loadimage address 536870940 foffset 229376 16384
writing 16384 bytes at 245760
loadimage address 536870940 foffset 245760 16384
writing 16384 bytes at 262144
loadimage address 536870940 foffset 262144 16384
writing 16384 bytes at 278528
loadimage address 536870940 foffset 278528 16384
writing 13108 bytes at 294912
loadimage address 536870940 foffset 294912 13108
13108 bytes written at address 0x2000001c
downloaded 13108 bytes in 0.186010s (68.818 KiB/s)
shutdown command invoked
I guess you already resolve the issue.
The snip.scan app is loaded to the mail flash of the MCU.
The .../apps/waf/sflash_write app loads all following JTAG data to serial flash.
* SPI Flash Write Application
* This application is used by OpenOCD and the WICED build
* system to write to serial flash. The app is loaded into
* MCU RAM directly and once running, interacts with OpenOCD
* to write consecutive chunks of data received via JTAG to
* serial flash.
* The linker script places two of the structures
* defined by the app at the beginning of RAM. These structure
* variables contain all the details of the commands
* to be executed and data to be written
Seyhan
GregG_16
50 sign-ins 25 sign-ins 25 comments on KBA
This requires you to enable external resources. We will look into this and guide you on how to enable external resources.
GregG_16
Any update?  I sent you a separate note.
Dear Sir,
Store the Wi-Fi firmware in external serial flash by flash programmer tools. the app load wi-fi firmware and work normal.
But it can' t download sflash.bin to external spi flash by make snip.scan-BCM943362WCD2-FreeRTOS-LwIP-SPI SFLASH=app-download.
Did it need external ram ?
Best Regards
Chuang Chen
* serial flash.
Seyhan
