I m Working With BCM43907 Custom Board and When I try to Download and Run I am Getting error while downloading the binary.
Error:
Warn : Invalid ACK 0x7 in JTAG-DP transaction
Error: Debug regions are unpowered, an unexpected reset might have happened
Error: error restoring dfar/dfsr - dscr = 0xffffff3f
Error: Could not read DSCR register
Error: mem2array: Read @ 0x004a0018, w=4, cnt=1, failed
apps/waf/sflash_write/sflash_write.tcl:108: Error:
in procedure 'sflash_write_file'
in procedure 'program_sflash' called at file "apps/waf/sflash_write/sflash_write.tcl", line 277
in procedure 'memread32' called at file "apps/waf/sflash_write/sflash_write.tcl", line 225
at file "apps/waf/sflash_write/sflash_write.tcl", line 108
Full Logs Given Here:
Open On-Chip Debugger 0.10.0-dev-00224-g217aaab-dirty (2016-09-08-15:37)
Licensed under GNU GPL v2
For bug reports, read
  http://openocd.org/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
trst_and_srst separate srst_nogate trst_push_pull srst_push_pull connect_assert_srst
adapter speed: 100 kHz
adapter_nsrst_delay: 200
jtag_ntrst_delay: 200
post_init_43909_setup
Warn : Using DEPRECATED interface driver 'ft2232'
Info : Consider using the 'ftdi' interface driver, with configuration files in interface/ftdi/...
Info : max TCK change to: 30000 kHz
Info : clock speed 100 kHz
Info : JTAG tap: BCM43909.cpu tap/device found: 0x5ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x5)
Info : BCM43909.cpu: hardware has 4 breakpoints, 4 watchpoints
force hard breakpoints
BCM43909.cpu: target state: halted
target halted in Thumb state due to debug-request, current mode: Supervisor
cpsr: 0x000001f3 pc: 0x00000000
D-Cache: disabled, I-Cache: disabled
cortex_a interrupt mask on
adapter speed: 10000 kHz
cpsr (/32): 0x000000D3
lr (/32): 0x00000000
32796 bytes written at address 0x004a0000
18232 bytes written at address 0x004a8040
32 bytes written at address 0x004ac778
292 bytes written at address 0x004ac798
downloaded 51352 bytes in 0.723015s (69.360 KiB/s)
entry_address= 4882496
stack_address= 4911440
buffer_size= 32768
pc (/32): 0x004A8040
Total write size is 7996
writing 7996 bytes at 32768
cpsr: 0x800000f3 pc: 0x004a8d50
D-Cache: enabled, I-Cache: enabled
loadimage address 4849692 foffset 0 7996
7996 bytes written at address 0x004a001c
downloaded 7996 bytes in 0.120002s (65.071 KiB/s)
cpsr: 0x600000f3 pc: 0x004a8dda
cpsr: 0x800000f3 pc: 0x004a8de2
MichaelF_56
The BCM43907 has not been released to the broad market yet, so as such, it is not supported here on the WICED Community.  Please work with the Module Partner (IoT Solutions Guide) or local Cypress Sales/Distribution partner that enabled you with this platform in order to setup the appropriate factory support.
AxLi_1746341
Level 7
Level 7
10 comments on KBA 5 comments on KBA First comment on KBA
FYI, I see similar error log on BCM4390:
https://community.cypress.com/message/27975#27975
Unfortunately, no solution from cypress.
Hi axel
Do you have any solution for the above Question?
muralidhar wrote:
Hi axel
Currently if the device keep showing this message and not able to recover,
I jut throw away the device because I don't have any solution so far.
