Dear Broadcom communities
As the are new modules with it, please, can you precise the power consumption
Maximum and Minimum
and depending wifi/bt, and speed if needed...
then is there a low power mode ?
Additionnaly, staying wifi connected but no transfert, power consumption and time to standy, recover...
We are wondering for wireless wifi data acquisition on batterie..
Waiting for some link if there are..
Thanks and have a great day..
Jp
There are power consumption values for the chip itself noted in the datasheet: BCM4343W Data Sheet (2.4GHz 802.11b/g/n, BLE/BT)
In addition, Power Topologies, Power Design Tradeoffs and other power topics are discussed as well.
Ultimately, because we do not support chip designs directly here on the forum, you will need to find a Modules and Development partner with a 4343W based design that can share more specific values with you.
A list of the partner modules available today can be found in the back of the Mass Market Products - Fall 2015 Product Selector Guide
Dear mwf_mmfae and community
Thanks for the reply,
ok better is around page 140 and 141 in the datasheet
but if some have done real measure on module is welcome please.
Best Regards
JP
