We have a requirement to control BLE Tx Power in our application running in advertisement mode.
We need your help in decreasing the BLE Tx Power on the BCM43012 module in advertisement mode.
It will be better if we have a command to dynamically change the BLE Tx Power.
If the BLE Tx Power is always Fixed per HCD file then please share with us the HCD files with different power levels.
Below are the required Tx Power levels.
1. With -15dBm
2. With -18dBm
3. With -20dBm
Attaching the HCD file that is currently used on our board (BCM43012C0.1LV.hcd.zip).
Please let us know if you need any more details.
@DheerajPK_41 @GauravS_31 @SheetalJ @VictorZ_46 @VinayakS_26
Manoj
WICED Studio Wi-Fi Combo
Hello @maku_3939256
We cannot release hcd files with different Tx power on community platform.
Can you please get in touch with your Infineon FAE and create a Techsupport case for this request?
Anjana
Hello @maku_3939256
Anjana
