I'm using "Avnet bcm4343w IOT Starter Kit" now,
and I'm trying to drive it with SDK v6.4.0.
But when it runs to wwd / wwd_buffer. c - > internal_host_buffer_get, it crashes.
I saw this article saying to use 3.5.2:
could any engineers can able to help me ?
or give me a copy of v3.5.2, i try it again in old version.
- avnet bcm4343w
Are you already done with the porting of BCM94343W_AVN platform files to your current version of WICED SDK v6.4.0 ?
Thank you for you reply.
the question has been solved.
i use the wrong platform : BCM943938WCD1,
when i change to BCM94343W_AVN, it works!
WICED SDK 6.4.0 is great !
