I'm Used WICED SDK 3.5.2
Appliance app test.
I'm modified appliance.mk file below add two line.
FR_APP    := $(OUTPUT_DIR)/binary/$(CLEANED_BUILD_STRING).stripped.elf
DCT_IMAGE := $(OUTPUT_DIR)/DCT.stripped.elf
and BM30_ext platform used build.
demo.appliance-BCMUSI30_ext download download_apps run
wiced_config_device wep ui access.
but, below under display web ui.
appliance.mk delete two line
is normal display.
My test app is need to web ui access(wiced_device_config) and ota_fr apply.
JeGu_2199941
25 likes received 10 likes received 10 likes given
Just guessing, maybe there isn't enough space in flash ?
As far as I know BM30 is internal flash 512K
If demo.appliance-BCMUSI30 download download_apps run build error.
-> region `APP_CODE' overflowed by 23068 bytes
So, BM30_ext platform use build.
But, appliance.mk is not include two line is normal behavour.
Attach file apply and demo.appliance-BCMUSI30_ext download download_apps run
Web UI display error.
I guess device_settings.html file parsing error.
I need help this issue.
Suggest you to try with 3.7.0 SDK release
Agree!
If internal not enough flash! How much external flash size ?
And you also mention , if there are NO FR_APP, which is work fine!
You need to trim your application to reduce image size to fit into flash size
This issue is not internal memory size.
XX_ext platform build is App_code and filesystem  external flash download.
This issue is attach file apply appliance test app is same.
Does not matter my application image size.
USIBM30 is internal flash 512k. So, USIBM30_ext platform used.
BM30 default platform is appliance app is build error
-> region `APP_CODE' overflowed by 23068 bytes.
So, demo.appliance-BCMUSI30_ext download download_apps run
But, appliance.mk remove two line is normal behavour.
XX_ext platform and appliance.mk two line add -> web ui display error.
JoYi_1844281
Level 6
Level 6
100 sign-ins 100 replies posted 50 likes received
Where the remind image size move  ? if you build with USIBM30_ext platform !
How big your FR_APP ?
How big your external SPI flash ?
if your FR_APP and file system image size over the external flash size ?  What happen ?
