I have configured my code to write exceptions to AONRAM to survive a reset and push the information out on the next reboot. This leaves me with a register dump of addresses. How do I determine where the LR address is pointing to? If I am running in debug mode, the debugger will stop and I have insight into the location with the disassembly window. Since this is a release image, is there a way to set GCC to build a list file?
On this site,
https://www.systutorials.com/240/generate-a-mixed-source-and-assembly-listing-using-gcc/
they mention adding the following commands to the GCC parameter list
-Wa,-adhln -g
In what makefile would I add this?
Processor: CYW43907
ispn:36623:1:0
l1:3966:1:0
l2:6066:1:0
You can add the flags in COMPILER_SPECIFIC_STANDARD_CFLAGS in 43xxx_Wi-Fi\tools\makefiles\wiced_toolchain_ARM_GNU.mk file
Thanks Priya
