Wi-Fi Combo Forum Discussions
JaCr_2843841
First like received
One of our customers is trying to get KCC certification.
KCC requires less than -54dBm integrated power at 1MHz RBW.
Our module, based on CYP43362, is failing by about 5-8 dBm.
Is there any way to tweak LO power or feedthrough using NVRAM parameters?
thanks
PriyaM_16
25 solutions authored 10 solutions authored 5 solutions authored
Kindly go through the regulatory manual for understanding the complete procedure of obtaining certification http://www.cypress.com/documentation/application-notes/an225347-cypress-wi-fi-clm-regulatory-manual
PriyaM_16
Is the failure during RX mode? Also is your failure at 3GHz?
PriyaM_16
