Added CORS support to WICED http_server.c to make JSON testing easier
AnSa_1225656
Level 4
Level 4
50 replies posted 25 replies posted 10 replies posted
I added the
    "Access-Control-Allow-Origin: *\r\n" // This line added to enable cross site scripting
line in the top of the http_server.c in Library/deamons.  It allows me to build my web site as files on my PC and go against real JSON data from my device.  Thought it might be handy to others.  Let me know if there is a better approach to adding CORS support.
<snip>
static const char ok_header[] =
    "HTTP/1.0 200 OK\r\n"
    "Content-Type: ";
</snip>
AnSa_1225656
Level 4
Level 4
For 3.1.2
----In http_server.c----
    /* Content-Type: xx/yy\r\n */
    wiced_tcp_stream_write( stream, HTTP_HEADER_CONTENT_TYPE, strlen( HTTP_HEADER_CONTENT_TYPE ) );
    wiced_tcp_stream_write( stream, http_mime_array[mime_type], strlen( http_mime_array[mime_type] ) );
    wiced_tcp_stream_write( stream, CRLF, strlen( CRLF ) );
    // Add following two lines to allow cross site scripting
    wiced_tcp_stream_write( stream, HTTP_HEADER_CORS, strlen( HTTP_HEADER_CORS ) );
----In http_server.h----
#define HTTP_HEADER_CONTENT_TYPE       "Content-Type: "
// Add the following line
#define HTTP_HEADER_CORS               "Access-Control-Allow-Origin: *"
#define HTTP_HEADER_CHUNKED            "Transfer-Encoding: chunked"
